Coating turnbuckle stabilizer
rrman61
Is there something better than grease gun or similar grease on a tractor turnbuckle stabilizers threads to prevent them freezing up on a tractor that I rarely change implements?not misuse just little use
NAPA Chain and Cable lube. It's a thick oil type lube that doesn't gum up over time. It's is my go to on a lot of things other than motorcycle chains. I like to carry a can on the tractor for turn buckles and such. A small amount will go a long way. Just degrease and clean the threads before applying.
MACS open gear lube. It's water proof and will stick to just about anything.
If you want to stick with grease. Jet-Lube Extreme Artic grease is good. They have two types. On is a Calcium Soap and the other is a Grade 2 grease. . It's what we used on our combat tanks in cold weather.
