cockshutt 1650 wheatland remote issues
Dave anola
Well still having issues ....
Last time I had the loader stuck in raised position with weigh and could not lower it even after curl and dropped the load. Took both valves out and took raise lower valve apart replaced both couplers on raise / lower side. I didn't anything suspect so reassembled with suspect valve in curl position to see if issue followed and it did.
I was able to use for some lifting (run forks on it) and get thru summer until now won't lower again (always chattered when lowering big weigh) Anyone had similar issues ? AGCO says some poppets are discontinued. Is there an aftermarket part source to overhaul the remotes ? Wondering now if they are the issue. It seems like the hydraulic system is under pressure and leaks at power steering / cannot uncouple pioneer couplers without relieving pressure (loosen a few threads and let leak down ) Could it be building backpressure in the system ? Trying to not just throw parts at it while praying
Thanks Dave
Hello
I spoke to the AGCO parts desk guy yesterday he said in the US the dealers showed some of the part numbers as available but others as discontinued.
I am still unsure where the issue is (don't see anything obvious) I have replaced the filter on the left side of the seat both couplers (double checked flow ) they are fine.
It seems that even when it was usable raise / lower only that the pump was under constant load like the steering was at the end and the pump is building pressure ( don't want to blow any hoses or seals )
Is there some adjustments I could look into ? reason dual acting remote wouldn't / wont lower?
Thanks Dave
Hi Dave
Where are you located? I think I have found some poppets. Can you reply to my E-mail....bottom right, classic view.
Wayne
