Big Puller
Where is good place to get Cockshutt 20 brake parts
You can get the parts from MIKE DAUGHERTY, Warren, IN 260-375-6018. New speedi-sleeve or a cheaper alternative tighter fitting brake pinion seal that that will compensate for the wear groove that is worn into the rear lip of your brake drum. Either of the above should be cheaper than machining the drum's grooved wear surface.I'm chiming in with a question on the open brake drum. I have a '52 E3 CoOp and it leaks extensively past that seal. I'm thinking it's b/c of the drum inner having a worn valley where the seal is.
I'm thinking of having a machine shop weld/build up and recut. Would that be a good fix?
I did, but am also trying forum for different part numbers optionsHave you called Mike Daugherty, whose number is listed above? There are some members on this site who have a wealth of information and I would try that number first.
Thanks! Any idea on torque spec for those 2.5" big boys?The left one should look like the right bolt. .Tap in the button on the left to look like the right one that is in the proper position.
Phil Heisey
215-256-8651
