Cockshutt 40 with front loader
Just wondering if any one has a cockshutt 40 or 50 with a front end loader on. I"m looking at hooking up the hydrolics from the rear remotes to a duel spool valve to run the loader. Or would there not be enough hyd cappicity / pump pressure to run it off of the rear remotes.? Thanks for your help guys
You would be very disappointed with that type of set-up. 1000-1200 psi small capacity pump. The reservoir is also small. Highly recommend PTO pump with external reservoir.
