Cockshutt front hubs
kb88
I have a cockshutt 50 I'm looking to put 6 bolt hubs on and was wondering what hubs will fit in the spindle and what rim offset I need for 7.50-16 tires.
Thank you
What kind of front end. Most any of the hubs are interchangeable except for the heavy standard wide. Irv
it probably has the cast hubs that use the 5 tab rim. if so any of the 6 bolt hubs from the cockshutts will work. Other brands may work but you may have to play with the bearing and cup to find the right combination. As for the rims you will just have to test fit or measure and look for one that will work. they are out there but if your wanting a wider one you will have to find one with an off set center so it doesn't rub on the inside. Irv
Ok, as I said earlier they are different. I had do do a little research before I got back to you to make sure my information was correct. The heavy standard wide spindle in side hub bearing shoulder is thicker and the bearing slightly larger. The out side hub bearing is the same on all hubs. If you can find a bearing cone and cup combination that will accept the larger spindle and the smaller hub I believe you can use any of the other hubs. Other wise you need to convert to the lighter standard wide front. Irv
