Any are suitable if you use the correct resistor with them. Typically the 12v kits come with 2.5 ohm coils for front mount distributors. Side mounts can use a 3 to 3.25(IC14SB) to maybe 4 ohm coils with no resistor at all.
The 12 volt negative ground Pertronix kit I put into the Oliver uses a 3ohm epoxy coil with no ballast resistor.
uh John?......since when did yer Oliver have a 4-nipple distributor with squarecan ignition coil??? .......respectfully, Dell
