xcess heat primarily comes from too much current when it is the wrong coil for the application, perhaps as when a 1.6 Ohms coil for a 6v application is used on a 12v system without an appropriate current reducing ballast resistor, instead of a 3 Ohm coil for a 12v system..(quoted from post at 09:43:38 05/24/23) One thing that can cause coil failure is excessive heat. Can you remount it so it gets more airflow, or add a heat shield, perhaps?
hart's wrong with that one?(quoted from post at 16:31:25 05/24/23) This is my coil failure.
Coil was used on my 2007 GMC.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto155230.jpg>
I wonder how many Yters have coils, points and condenser failures because they don't use the right ballast?
t's pretty easy to test a coil with an ohmmeter. You'll have no trouble finding youtube videos on the subject.(quoted from post at 07:40:22 05/24/23) I have a 2510JD that just starts to miss and then won't restart if its hot. Next day it will run fine. Put a new coil on and it will be good for a couple of years. Is this common for coils, they don't seem to last as long as they used to. Just wondering. Thanks Jim
