Cold starts
jakey999
Just purchased 1967 Ford 3000, 3cyl. diesel last fall. Starts decent until cold weather (freezing temp). Using ether but don't like the idea.The cold start button,does not appear to help. Would a block or inline rad. hose heater,help. Thanks
jakey999
Did you check to see if the manifold heater is working?
"Carefully" run a temporary wire to the heater terminal, to check to see if it heats up.
The heater element is not expensive, or difficult to replace.
A block heater is a good investment.
It provides a nice warm start for old (all) tractors.
Brian
My '82 Ford 4610 has a Thermostart system on it and that's good to about 15F. A block heater is a lot better. I haven't found the lower working temperature for it but it did start at
-15F which is a low as it got around here so far this winter.
In my opinion, the block heater is the best starter assist device for a diesel at cold tempertures. Philipps-Temro makes a lot of them and you can find there website by gogling their name. Be careful with starting fluid 'cuz you can break rings if you over do it.
You have to make sure that the throttle is held back to half or more before you push the cold start button in, otherwise it doesn't pull the rack back past the stop... but it's not the be all, end all either.
A 3000 may very well have not had a thermostart/manifold heater. It could be added...
A block heater would be the best option and probably the cheapest option if you've always got it handy an outlet. I prefer the block heater over the hose heater because it's easy to install. Putting a hose heater in the lower hose on those things is not my idea of how a good day should go. I'd sooner pull the starter an put the core plug heater in...
Rod
Thanks Brian, I don't know if this tractor has a manifold heater. I looked for one , but found nothing, also the wiring was replaced, so possible not rewired. Thanks.
If you have a Simms injection pump it is located at the center of the stop valve lever on the
injector pump housing.To operate, Stop button on tractor pushed in and trottle lever at about half. Then push in cold start button. Wayne
