Cold valve lash on a Z
Shouldn't make any difference. Adjust so the all have clearance roughly then do an accurate after warmup. It's not like you are playing with a precision motor. Done lots that way.
Dennis P,
The cold valve setting on a 206B-4 ZA engine is 0.010" for the intake and 0.018" for the exhaust.
The hot setting for the intake is 0.008" and 0.010" for the exhaust.
These settings are ZA factory published numbers from a S-147 MM shop manual.
Enjoy the task and happy wrenching.
Charlie at
Moline Parts
Please take note about valve settings. The M-M valve specs. are wrong in the book. I have found out the hard way. 8 and 10 will burn the valves in just several days use. Been there and had it happen on Z s , U & G tractors . Never had problems set at 12 and 14. With that setting they mite be a little noisy, but I never had a burned valve in 30 + years of heavy use.
Look in a service manual for late model M-M s , they list a wider settings. clint
Set intake at .012----exhaust at .018----I was a dealer for 17 years many, many years ago-----
owner dealership 1953 to 1971
