Cole fertilizer sidedresser
aarolar
Does anyone have a pic of the proper way to mount a ground driven Cole sidedresser to a Pittsburgh cultivator frame? I just can't see a good way to mount it up studying it.
Those are easy to mount. All the mount was is two pieces of angle iron that bolted to the front cultivator cross angle. Then the small angles just are a 90 degree brackets that bolt to where the cross member is on the very front of the side dresser. There is a short bushing that allows the side dresser to pivot up and down. When the cultivator is down the rear wheel is on the ground with the side dresser frame off the back cultivator cross frame. When you lift the cultivator the side dresser frame rest on the rear cultivator cross member to lift the drive wheel off the ground.
The picture is of a Cole but you can see the mounting brackets on the front of it.
(quoted from post at 06:07:37 03/11/16) Planter - Side dresser instruction books are avaiable from Covington . Google is your friend.
I'm skeptical that they mount the same the drop tubes come out at a completely different place and if I mount it the same way as a covington then the funnel for the drop tubes is going to hit the cultivator frame.
(quoted from post at 17:24:57 03/11/16)
Give them a call (229-888-2032) (Cole & Covington are the same company now) They are located in Albany Ga. and I am sure they would be willing to help you.
