Combine Elevator Flights
HenryBros
For those of you with operating Case combines, what is a good source for rubber elevator flights and chains? Several flights need replacing on our 960 combine but I have yet to find a source for anything. Thanks for any suggestions.
When I had rats get in the elevator on a MM corn sheller I made the rubber pieces out of 3/8" plastic. I cut them out with a skill saw. Very easy to work with. I would think the chain could be found with out much trouble.
I believe a chain from an IH 403 will fit if you
trim the paddles a bit. I don't remember for sure
tho, but I know I used an IH chain in my 1160 last
year. Our local salvage yard has hundreds of new old
stock elevator chains and I just found one with the
correct chain and cut down the flights. Used on in
my 77 pull type too.
I have several (I will have to go to the shed and count) 10' rolls of new, original Case elevator chains, fits 460, 660 and 960. contact me if interested.
