combine motor
Anonymous-0
i had this on combine and harvesters and got very little information, but here goes. i acquired a diesel engine from a combine that was scraped out and the scraper cant remember the model of the mf combine. i would like to know the HP amd the rated RPM. it is a 4 cylinder diesel non turbo. injector pump is a CAV. delco remy starter. oil filter canesre is AC. left back side of block is stamped 693109c. cast into head is37116200-3. mumbers cast into is 57781750 (exaust manefold) thanks. engine size model # of engine
That sounds like the Perkins I had on my 410 Massey that I sold 6 years ago to the Amish. At the time I new that info but I had it written in the op manual and gave it to the guy.
(quoted from post at 10:21:09 03/17/10) i had this on combine and harvesters and got very little information, but here goes. i acquired a diesel engine from a combine that was scraped out and the scraper cant remember the model of the mf combine. i would like to know the HP amd the rated RPM. it is a 4 cylinder diesel non turbo. injector pump is a CAV. delco remy starter. oil filter canesre is AC. left back side of block is stamped 693109c. cast into head is37116200-3. mumbers cast into is 57781750 (exaust manefold) thanks. engine size model # of engine
I have my AERA -Enine Rebuilders Association manual out.It shows it to be a MF model 4.318 cubic inch 318 inline 4.Thats what the head cast# tells me.I can not find the block cast#.Also shows the same cast# for the Perkins 303 and 318 inline engine.Looks like the MF super 90 had a 302 cid.MF 285,1080,1085 had the A 4.318 cid engine.Don't know witch is tractors or combines.Hope this get you a little farther in your search .BlaineF
