Combining oats
jon f mn
Spent last weekend combining my oats. Had some trouble with the first field that I never really figured out, and had a few breakdowns. So what should have been a few hours took all weekend. For what ever reason the first field would not feed into the machine. It either would not feed into the header auger or would build up between the auger and feederhouse chain. I have used this header several times and never had an issue. I made every adjustment that could be made to it in every direction and the best I got it was to feed very poorly. Add in a couple breakdowns and it took most of two days to do 6 acres. Then the second field fed perfectly as always and only took an hour and a half or so. Both fields planted and cut the same day and crops about as similar as possible. So no idea why it was that way. Tom the case combine expert says its aliens. I can't dispute that.
So here are some pics
Here is a video of the field that fed properly
Combining
Looks good. I only used a pickup head on my Deere 105 once and it worked great. I could run a good bit faster than strait cutting. Did find out you have to go the same direction as the swather. Tom
Reduce the tension on the windgaurd.....the long metal fingers above the pickup reel....Looks like they might be pinching the straw and not releasing it as it comes off the pickup . Sometimes it is necessary to rake the window so it's more uniform and the heads feed in first a bit better. I bet you learned some new swear words! Otherwise, it looks good, nice tidy machine.
Ben
Jon,
Looks like you had some fun.
I see a corn crib in the background, will there be a Case picker and a hay/grain Case elevator in the future? Did they make a stand alone sheller?
Maybe the oats were tough in the first field. The JD 915 head I have is real fussy when it comes to tough material. Just this wheat harvest I had similar issues for two days after a very heavy rain then the wheat cut perfectly without adjustment. Seems like you can try all the adjustments in the operator's manual but the conditions have to be good. The old Gleaner L was better in terms of tough material in the head but would bunch up at the beater. No fun unplugging the beater.
Looks good. Combining swathed grain was my favourite. Direct cut always seemed to have issues with some green stuff or tough straw. And I liked that I could shave the field down tight with the swather to get all of the straw, and not worry about putting a rock through the combine
This is rented land, but that crib may get to my house some
day. I do have a case elevator and picker. I'm not aware of
any stand alone Sheller. They did make a two row pull type
picker sheller tho. I would love to get my hands on one of
those some day.
Case elevator on auction close to me. Never seen one with the single chain paddles. The side fold down for hay too
We had allot those elevators back in the day in my area as we had several big Case Dealers close buy, still run into them now and then. My Grandpa had one in the Fifties and I can remember folding the sides up and down depending on weather we were moving hay or grain.
I agree with centash about reducing the tension on the wind guard.
During my growing up in North Dakota (1950s and 60s) all small grain was swathed and combine pickups typically didn't have wind guards.
I'm kind of jealous, I always enjoyed those jobs ,first with a pull type JD #60 with Oliver 1800 and then a 410 Massey. Love the smell of the oats in the hopper, and seeing all the grasshoppers who somehow got through the machine unscathed.
Like centash said, I think you need to raise those hold down fingers. Also I think I would run the pickup a little faster. The field where it worked good were the oats taller. I think it would work better with longer straw.
I thought that might be the issue so I took them off. That was worse so I put them back on. They are not heavy as they are just plastic pipe and there is no down pressure so I doubt there is more than a couple pounds of force on them. I did consider making the heavier to hold the crop against the pickup and roller better. But I never got to it.
I believe it all has to do with it being a small windrow.
I have an IH belt pickup on my Case 2144 combine and it does not like small windrows or short straw.
Was a good year for oats here finally, tho oats is a worthless crop around here. Selling it for $2.25 to a neighbor, calf feed. Was 34# test weight. Way up from the 27 to 29 we have had the last wet years.
Barley I had trouble feeding into the combine from the windrowing. It was so short the stems fell back straight from the swather and settled down, the pickup belts couldnt pick them up. If they were at an angle the fingers would have grabbed, but I couldnt get it to work. Left 5-10% of the barley stems laying, still had a good yield this year.
Paul
I did not watch the videos and would bet on the parts not being polished from use. Rusted parts will not feed good no matter how it is set. We used to have that each year at the start with any thing combine mower and such.
