Combustion Ignition Gasoline Engine
not quite sure I understand the difference it still has a spark plug it looks to have a domed piston for high compression , it would seem it would to detonate , Im sure it works though
Technologically feasible and probably produces more torque due to higher compression but ignition timing will be difficult and detonation hard to control.
Probably requires high octane fuel.
One wonders what the advantages are.
Dean
<a href="https://news.mazdausa.com/2017-10-24-mazda-next-generation-technology-press-information/">This page on the Mazda</a> site explains it in more detail.
So what they're doing is to boost the compression ratio up close to that of a diesel. The combustion chamber isn't quite hot enough to ignite the fuel-air mixture, but when the spark plug fires the additional heat causes a diesel-like ignition. But not quite a detonation, either. Depending on operating conditions, the engine may operate as a regular spark-ignited gas engine or as a spark/compression-ignited engine.
It seems that what they're trying to do is to move as much of the combustion process as possible between top-dead-center and 90 degrees after TDC, which is when the piston is accelerating. Gasoline engines typically fire before TDC to try to get maximum combustion chamber pressure in this region. Using the spark/compression ignition, Mazda is able to retard ignition to TDC and still get the maximum pressure during the 90 degree sweet spot.
I remember when Mazda came out with their rotary, a buddy actually bought one HE REGRETED THAT DECISION FOR YEARS LOL I dont view it (maybe the later) as the next big technology, but hey if they come up with something Im willing to take a look.
John T
Combustion initiation and a clean burn at idle and at low rpm . Is an altogether different kettle of fish than high power output at any rpm .
DI gas use staged injection of fuel with lean on the perimeter and a richer kernel in the middle of the chamber chamber when putting around . And extreme swirl to control detonation along with injection of fuel just Prior to the the spark . To allow high compression without detonation at high power levels .
Diesel, Kerosene . Gasoline , alcohol , LP ,Natural gas and hydrogen . In that order of dirty to clean .
In time #2 diesel will be a niche fuel for large HD only applications. as #4 diesel and #6 diesel is now .
Are there any engines in production today that require or even prefer #1?
