Back again.
So I relapped all of the valves and used water and air to check the seal. No bubbles so they are now sealing well. I have the injectors serviced and re assembled. When I tested the compression, cyl 3 was still down compared to the other 2 but the diference was less than 10%.
The problem I am getting...
Running a topper for about an hour and the power drops such that I cannot get the revs above 1400rpm. I disengage the topper and the revs take about 10 seconds to get back up to 2000rpm. So I re-engage the topper and immediately the revs drop back down.
So I drive back to the barn, wait about an hour or so. Try again and the same thing happens, after about 30min to 1hr, the power drops again.
How do I establish what is going on?
Cracked cyl head?
I am pretty sure the fuel system is OK, but is there anything I might have missed.
I have had problems with the strainer in the tank getting blocked, so it's currently removed.
Should I test fuel pressure? What is the best way to do that?
Tbh I am very close to throwing in the towel, jobs are backing up.
Thanks for your time.
Cracked cyl head?
