Compression on 1950 8N
leroy1142
Can anyone tell me what the compression should be on my 1950 8N tractor. I would like to know the hi end and the low end. I keep hearing that you should do a wet and dry test, what do they mean by wet and dry. The engine that I ran the compression check on is as follows. I have 120, 108, 108 and 83. Thank you for your time.
leroy1142
On the N series 90 is about as low as one want to have an engine that runs well. As for wet and dry test it is this way. You check compression dry as in right after you have run it to warm it up then check then after the first check you add a table spoon or so of oil and then check again. That 83PSI says that cylinder has a problem like a valve that is not closing and or stuck or broken ring etc.
LeRoy.........Ford specs fer 8N is 90psi min; good runnin' 8N's are about 110psi; brand new rebuilt 8N's about 125psi; ........HTH, the amazed Dell
OLD, I thank you for the information it is helpful, but I steel would like to know the compression ranges.
leroy1142
A good fresh rebuilt engine will have up wards of 125PSI maybe a tad more and a engine that is pretty close to worn out is 90PSI and under. That is on the N series flat heads
I don't know the actual specifications for that specific engine, BUT.....
The spread between the highest and the lowest cylinder should be no more than 10%.
The spread from 120 to 83 is too much. It indicates a problem with a weak cylinder. Could be rings, valves, or head gasket. The wet/dry compression test would help to pinpoint whether it is rings or valves. A leakdown test will tell if it is a head gasket, rings, or valves.
