So I am pretty much done pulling my engine on my 2n. Low Oil Pressure and fouled plugs were my main reason for deciding to 0 time the engine. I get the idea that I would like to do a compression test. I can't warm the engine and each spark plug was oily when removed.
1. 100 psi
2. 90 psi.
3. 90-95 psi
4. 105-110psi
Should I consider these numbers wet and???
What is the max psi of a fresh rebuilt engine? My FO-4 only says 90 psi min and no more then a 75% difference.
Side notes, My water pump had a stud twist off at the flange when removed so I have about 1/2-3/4 inch of rusted stud still remaining. My Main Axle Pin does not look like the ones I see for sale on this site. Not sure what I am seeing as it is all covered in grease, but it is a large triangle plate with two pins on the bottom pointing forward (I didn't measure it, but I am assuming it was around 6inchs tall and 6 inches wide at the bottom) and it had one 5/8 fine threaded bolt in the middle of it. I think it is a loader mount plate. The front axle pin is warn significantly and should be replaced. The two arms that stabilize the front axle. The bolts that go through the front axxle were worn out. I had to remove the head of the LH bolt to drive it down and out.
Does anyone have any advice for me??????
Thanks, Jeff Eck
1. 100 psi
2. 90 psi.
3. 90-95 psi
4. 105-110psi
Thanks, Jeff Eck
