compression test
Ian Poland
Could someone tell me what the correct procedure is for checking the compression on my 1956 Ford 650 134 cid engine. I'm more concerned with which wire to remove from the distributor...middle coil wire? Thanks for all your help!
Compression tests should be done on a warmed engine, ALL plugs out, fuel turned off, ignition turned off, and throttle wide open ( opens air flow / butterfly ).
Do a dry test on each cyl.. at least give it 5 puffs.. but some of us keep cranking till the gauge stops rising.. so may be a few more than 5 puffs. doe each cyl.. jot it down.. now put a tablespoon of oil in the cyl and test again.. this is a wet test.
a low dry reading that comes up on a wet reading is indicative of ring wear.. a low dry reading that does not come up on wet is indicative of valve leakage.
soundguy
Is there a fuel shut off located somewhere, and what do you mean by ignition off? Don't I turn the motor over for the test with the ignition?
Thanks again Soundguy!!
If your hundred series is stock.. there will be a fuel shutoff valve in the tap from the tank.
Starter button and ignition key switch are 2 completely seperate circuits..
Key switch sends power to the ignition coil.
Big thumb button on the trans cover is what makes the starter spin.
Are you saying that you don't have this setup and someone has garbaged up a key-start system like on a car? bypassing the SAFETY INTERLOCK start system it came with?
post back...
soundguy
It does not have the original key ignition switch, but does have a toggle swith in place of it that activates the coil. It also has the starter button on the tranny cover to start it. So when doing the compression check are you saying fuel off, key switch (toggle) off, throttle all the way open, and use the starter button on the tranny to turn it over. I thought the key switch had to be on to turn over the engine?
Thanks again!
Ian
If it still has the oem solenoid, it will turn over with the thumb button without the key being on.
If your's hase been finagled with to need the key on, then just unhook the power wire going to the coil.. etc.
soundguy
Soundguys advice is the way 99.9% of us do the compression testing.
The FORD way is for the engine to be running at 1000 rpm and it should reach 205 psi on a new engine.
The FORD way is a PITA so, do it SG's way. Post back with the results in a little table with cyl,dry, wet listed for each.
jb
It should turn over with the ignition off and the tranny in NEUTRAL. If oem it will not turn over in gear. HTH
DON TX
