compression
The I & T manual gives a c.r. of 5 or 6.2 depending if you have a L. comp or H. Comp. model. I would think L. Comp. Would be a tractor fuel model, H. Comp. regular gas, and if you had LP heads it would be higher than 6.2 even. The main thing for compression is that it should be nearly the same at all cylinders. They do not give a pressure number.
Bryce
