Thanks to the archieves and the many contributors I have decided to use 3/4" copper for my main lines and 1/2" for the drops. Out of curiosity I have only 1 question: is there any concern when using fittings / pipe of different metal type . I've read that you shouldn't connect iron pipes to copper, and if you want to there is a die-electric union you can use etc etc.
I'm using copper pipes the filters are aluminum ??, some fittings will be brass, nipples will be black iron etc....
Is there any concern with using different metals in the compressor setups ?? If so what should I NOT do ???
OR is this insignificant ???
Thanks...Alan
Thanks...Alan
