Any pointers are appreciated. My old mechanic is no longer with us he use to say "mike you can pay me now or pay me much more later" I usually drained the tank every 6 months very rarely changed oil or did any real maintenance.
I am installing an old Webster 80 gallon tank 5 HP 3phase in a new location. It used for air nail guns every thing is 3/4" hard plumbed. The pressure regulator was functioning ( 80lb - 125lb max) prior to my move and I would like to move the pressure up to 150lb max. The electrician may have goofed up or not really understand the protection relay I had installed after The motor burnt out due to running on 2 phases overnight. I seems to start when I press the start button and will shut down at 125lb. but will not restart when it hit the 80 lb. minimum seems like the pressure relay has 4 terminals and only two wires go to the Protection box? I will have to call the electrician back more $$$
