DMartin9N-2N
I have an HP laptop computer; I need to know if it will communicate with my HP printer without a cable. Otherwise, what cable will I need? Thanks for any info!
Or wired ethernet and plug into the router/network box. AND OR the printer will have a usb, serial port on the back for a wired connection. But most newer printers can connect to the network via wifi, and thus all computers can now connect and print to it. The hp "all in one" 7155 does/can connect to the network, so that all of your devices can now connect. Even smart phones. So that you can scan, print and fax with it.Printer needs to be wireless, Bluetooth.
Yup; my Canon printer is connected wirelessly to my cell phone too.Or wired ethernet and plug into the router/network box. AND OR the printer will have a usb, serial port on the back for a wired connection. But most newer printers can connect to the network via wifi, and thus all computers can now connect and print to it. The hp "all in one" 7155 does/can connect to the network, so that all of your devices can now connect. Even smart phones. So that you can scan, print and fax with it.
Now you got me wonderingI'm going to make a couple of assumptions:
Most HP printers support two different wifi modes: vanilla wifi and "Wifi Direct". Vanilla wifi just connects to your existing network, while Wifi Direct creates a standalone network where the printer itself is a router. Wifi Direct would be used to connect to the printer when there's no network available for the printer to connect to.
- You already have a wifi network in your home. Meaning you have a Wifi router someplace, and your laptop is connected to it.
- The "cable" connected between your iMac and your printer is a USB cable, NOT an ethernet cable.
Assuming you already have a wifi network, you should NOT enable Wifi Direct. Doing so will create another network in your home that devices will try to connect to, causing them to lose their internet connection.
You should be able to easily connect your printer to your existing network, using the printer's menu. You'll pick something like Setup->Network Setup->Wireless Setup Wizard. The printer will prompt you for the name and password for your local network. Once you've connected the printer to your network, any other device on that network should be able to find and use the printer.
Could be the printer. If in doubt, turn off Wifi Direct.Now you got me wondering
Ever since we bought a new printer my tv has been losing its wireless connection to the router
I just assumed the laptop my phone the tv and the printer were all connected to the router.
Never considered the laptop or phone is connected straight to the printer creating a different connection in the house
Ask AI, give it all your printer parametersI have an HP laptop computer; I need to know if it will communicate with my HP printer without a cable. Otherwise, what cable will I need? Thanks for any info!
That is most certainly not true. I routinely print over Wifi at two different locations; I don't use Bluetooth to print at all. Also, the printer (HP Envy Photo 7155) in question does not appear to support Bluetooth, but definitely supports Wifi, so Wifi is the obvious solution.I was surfing a day or so ago and that subject came up. The most positive answer was that the computer and printer have to be Bluetooth capable to talk to each other remotely.
Well I apologize for the disinformation. I didn't post it from memory. I have been having printer problems and I picked it up somewhere in the search for solutions to my problems.That is most certainly not true. I routinely print over Wifi at two different locations; I don't use Bluetooth to print at all. Also, the printer (HP Envy Photo 7155) in question does not appear to support Bluetooth, but definitely supports Wifi, so Wifi is the obvious solution.
