jjamna
What would cause a condenser to go bad. I have to put a new one on about once a year.Gets so bad after the tractor warms up good it just quits. Let it cool and starts right up. Just wondering if the points need to be set closer or farther apart or may be to hot of a coil. I tried to change to electronic ign. and never could get it to run. Even with talking with petronics on the phone several times. So I put the points back in and left the flame thrower coil on it. It is a 1010 JD
The coil might be 80% of the problem. The coil uses more current than a standard coil, and as a result can wear the points early. I have seen more bad new condensers than old ones. If the coil gets hot (feel it when it quits) Put on a standard coil for resistor if it using one, or no resistor required if none on it. Jim
Jim,
I do not remember new condensers failing like they do now, is my memory foggy or is this true?
I was told years ago that the condenser needs to be matched to the coil, leave the original one in forever as long as it works. There are no wearing parts to a condenser, it should last a long time. the idea of changing them every time you change points is foolishness!
#1 get the correct coil for the tractor.
#2 if the condenser is good it will out last a set of point 10 to 1.
I have not changed a condenser on any thing in well over decades and now days it is a 50/50 chance you get a bad new condenser
I suspect the coil may be drawing too many amps. Nothing to be gained by that coil on your application.
If you have the original coil, try putting it back on.
The correct coil is critical. If there is a resistor or resistor wire, it will need a 1.5 ohm coil. If no resistor it will need a 3 ohm coil.
The wrong coil, too much resistance, will cause weak spark and hard starts.
Not enough resistance will cause short point life and overheat the coil.
A proper matched coil will run about the same temperature as the surrounding components. If it is noticeably hotter, too hot to hold, something is wrong.
But even a mismatched coil won't cause the condenser to fail.
The biggest problem with condensers is poor out of the box quality. The point type ignition components are slow selling dinosaurs, little profit to be made from them. The production has been handed over to the few manufacturers willing to grovel by with antiquated, poorly maintained equipment.
You might get the Pertronics kit out, give it another try...
One other thing comes to mind, the condenser case must be well grounded. If the screw is stripped, and it comes loose, it will not work.
I haven"t been servicing vehicles for years. But I have seen none of mine fail in tractors, my 51 GMC 3/4, or my Jeep 57 CJ3B, or my lawnmower. I drive and use them and don't have a reason to fix what isn't broken. Just nit an issue. Parts people sell them (for old vehicles) because they make money doing it. However, cheap parts from marginal white box (or fake box) suppliers are really bad. Jim
jj, here is my analysis and recomendation.
1) That "flame thrower" coil may draw more current then the stock coil which could contribute to premature point failure...
2) That "flame thrower" coil likely has a different inductance then the factory original JD coil which may be part of the problem...
3) The coil inductance and condensor capacitance need to be properly matched and perhaps that non stock flame thrower coil, having a
different inductance, is causing premature condensor failure...
4) When an ignition shuts down only after its good and hot, that could be caused by HV breakdown of the coil and its NOT necessarily
a condensor problem.
5) I cant know what your tractor now has, if its been modified IN ADDITION TO THAT FLAME THROWER, or whatever else may have been
changed, HOWEVER if I recall (no warranty its been tooooooooooo long) "some" of those vintage Deeres used a ballast resistor located on
or near the ignition switch such as a resistive wire. Some 12 Volt Deeres of that vintage used a 6 volt coil and had an on or near
ignition switch ballast device IF YOURS HAS THAT (I cant know form here if it had or was modified, I saw MANY that got changed over the
years) I would take it back to original.
What I would suggest is to 1) Check to see if the tractor has any sort of ballast resistor or wire link or fuse wire on or near the ignition switch............ 2) I would REPLACE THE FLAME THROWER with an original Deere coil used on that tractor...........3) I
would install a new condensor properly suited for the Deere coil.......THEN SEE IF THE NEW CONDENSOR LASTS LONGER !!!!!!!!!!!!!!!
Like others Ive seen a ton of new condensors be bad out of the box and if all else is well (none of the above is the problem) they may just be bad.
Check for any ballast device, use an original coil, install a new quality condensor (if you can get one lol) let us know what happens. Again overheating ignition failure may be a coil or a mis matched coil and condensor problem, not necessarily a condensor problem alone
John T
We have talked about this before. In recent years there has been a lot of import condensers that do not work at all. They are crap and I think I am going to see if I can get the brand names of these fake or bad units. It causes a lot of down time and mechanics time. Saw two in a row on the same tractor. Bad, Bad, Bad.
There were so many crap caps in computer mother boards they finally switched to solid polymer caps which got rid of most of the problems.
It is customary to replace the condenser along with the points. A lot of good condensers were probably discarded. The reason, profit.
Many years ago people seldom bathed as often as now or washed their hair more than once a time. An advertising company came up with the printed instructions of the shampoo bottles Shampoo (or lather) rinse, "repeat". With those simple instructions that company doubled its sales.
I used to save my old condensers, but as times changed they were discarded, but this was before the imported condensers that have no quality control or have dubius origins.
It used to be that parts were cheap. If I pulled a plug out I replaced it. If I changed points I changed condenser too especially in a Chevy where you have to climb up over the engine to get to it. I still change condenser if I change points but generally I clean the points if I can.
