Confused about power beyond
jeffcarnill
I have a 3000 that has rear remotes controlled by the levers under the seat I’m wanting to add a loader to this tractor I also have another control valve(not mounted or hooked up)that has two levers the loader is currently on my international 240 utility and has a joystick controller what is my best option?if I install a power beyond adapter plate can I still use my rear remotes
I have a 3000 that has rear remotes controlled by the levers under the seat I’m wanting to add a loader to this tractor I also have another control valve(not mounted or hooked up)that has two levers the loader is currently on my international 240 utility and has a joystick controller what is my best option? if I install a power beyond adapter plate can I still use my rear remotes
Yes - thats the exact purpose of the plate.
TOH
IIRC.. there is a hv4902 and hv5902...adapter plate. the 4902 requires open center controls with a return to the plate for the rest of the hydraulics/3 pt, to work. The 5902 has an extra port, a power beyond port for closed center controls???? Its been a while.
Both plates are for open center systems snd have neutral OUT and neutral return ports for high pressure carry over (HPCO/PB)
The HV5902 has a third port for low pressure tank return. If using the two port HV4902 withh a 3 port control valve you simply run the tank return to any sump location. The hydraulic filler is a commonlly used location.
TOH
