If it has been banned it just means it is better. Buy elsewhere if you have to and haul it home.What grade of treated posts do they use to make boat docks?
CCA or AC2?
I realize some states have banned the sale of CCA,
Interestingly, treated lumber (landscape timber) is not termite proof. I set a mailbox post about 10 years ago, when it began to wobble last June I replaced it. When I dug up the below ground part it was nearly eaten away by termites.
Landscape timbers are poorly treated, even though they're normally used in contact with soil. You want a post whose label specifically says it's treated for ground contact.Interestingly, treated lumber (landscape timber) is not termite proof.
That and 10yrs laterLandscape timbers are poorly treated, even though they're normally used in contact with soil. You want a post whose label specifically says it's treated for ground contact.
And since landscape timbers are always 8 feet long there is a good chance he cut the timber to length to make this mailbox post and stuck the cut end into the ground.That and 10yrs later![]()
That's interesting! Last winter I found signs of termites under our home in Arizona, mostly on some lumber that was stored on the ground. I removed the lumber and sprayed everything with Permethrin, that's what was recommended, we will see how well it works. There wasn't any sign of damage to the wood that was on top of concrete, I assume it's treated.Interestingly, treated lumber (landscape timber) is not termite proof. I set a mailbox post about 10 years ago, when it began to wobble last June I replaced it. When I dug up the below ground part it was nearly eaten away by termites.
Landscape timbers here were a Douglas Fir 3 1/2" peeler core from turning plywood veneer. 2 sides were slabbed off making 2 slabs that were sold for cheap fence pickets. They were dipped in a "redwood" colored stain with a little bug juice. Used for a post, may last 3 years before rotting off.Landscape timbers are poorly treated, even though they're normally used in contact with soil. You want a post whose label specifically says it's treated for ground contact.
Around here landscape timbers are mostly yellow pine cores from turning plywood. They are treated with MCA at a rate of.01 lb per foot.Landscape timbers here were a Douglas Fir 3 1/2" peeler core from turning plywood veneer. 2 sides were slabbed off making 2 slabs that were sold for cheap fence pickets. They were dipped in a "redwood" colored stain with a little bug juice. Used for a post, may last 3 years before rotting off.
Termite bait stations; while they work; oh so slowly; they do more to pad the pockets of the pesticide company through monitoring than they do to kill termites.DIY pest control
Other sources as well for stuff for termites. Can do your own treatment spraying if you want. Weld a 6' rod to an inch drill bit to drill along foundation to spray/pump in chemical treatment. Dig a shallow trench along the foundation to pour in chemical. I knew someone who still had a supply of chlordane which has been banned from use but it worked.
Pros use the bait system but takes a year or two to kill them. They put the bait stations in with balsa wood and check them once or twice a year. If they find one that is eaten then they replace it with the termite killer they carry back to the colony. Nothing you can't do yourself. They use the wired ones that their detector picks up whether they are eaten on so they don't have to bend over to check them. Charge 300 bux a year to do one or two 5 minute walk arounds.
Termites are active outside during the warm months when ground is not frozen so they go deep. Like ants they nest down in the ground but deeper and they have to move to and from the source of food/wood. Spray and the residual effect kills them in their trail whether going in either direction. The bait kills them in their nest.
Heard someone say termite treatment just drives them over to the neighbors and the neighbors treatment may help yours. Let them pay.
It does get expensive if you have farm buildings. If I had a metal building with wood posts then I'd just treat down to the depth of each post.
