Contemplating H Engine Rebuild
primerk5
I have a 43 Kerosene H that still has its kerosene head with fire crater pistons. It’s a fixer upper I’ve been tinkering with over the years. Since I’ve had it, it has always had an internal engine noise and a lack of power. It would run though. Last year I had found the head gasket had been blown due to a head stud sleeve not having it’s washer under the nut and I had been hoping that might have been part of my noise. I had the head gone over for valves and valve seats and flatness. One thing I found while it was apart was the pistons seemed to be sloppy in the cylinders. You can lightly rock the piston back and forth from right to left in the bores. After rough measuring things it almost appears to have stock size pistons in overbore cylinders. I’m assuming its either that wore out or someone put the wrong pistons in the wrong sleeves long ago and just ran it that way. My plan is to pull out the pistons and check dimensions further on them and the sleeves, and try to determine what I have and if the pistons are still usable at all.
My actual question.
If I can’t reuse the pistons with new sleeves and rings, I’m wondering what I can get to replace them with and retain the kerosene head. I just want the tractor to run good and I don’t care to upgrade it for more horse power.
I see the in frame kit here on yesterday’s tractors. There is a “stepped” piston kit. Will that work with my Kerosene head? The picture of the step on the pistons look larger then my fire crater pistons and I’m concerned they may not fit into the head.
Here is a link to that kit.
http://www.yesterdaystractors.com/F...-C152-Gas-Stepped-Head-Pistons_BIFH1156A.html
Here’s a picture of my pistons.
Any over the counter piston sold for a H should clear the head. You have a high altitude piston now so the step head you mentioned probably could be a little lower compression. Piston you have was only made in 3-7/16 diameter so the sleeves can't be for the bigger size piston. How much of a wear lip at the top of ring travel can give a ruff indication or sleeve wear.
I looked to see if I had a picture that showed a ridge in the sleeve and I don't have it. I'm pretty sure that there was no ridge in any of the cylinders, just some carbon buildup at the top. If you zoom into that picture you can see the 1/16 gap to the right of the piston on the left.
So High altitudes pistons only came in the larger size? From what I remember the sleeves weren't scared up. Maybe this weekend's project will be to tear it back down.
Here's the dumb question of the day. Should I be able to wiggle the pistons left to right in the cylinders? I would think not. Never could in engines i had rebuilt.
Used ones will rock a little from side to side sometimes but shouldn't move but little. Hard to tell what's going on. Some one could have re ringed before and cut the ridge or the piston with to much space on the end to end side may not be square with bore and wearing the upper side above ring land more. Bent rod , bore off, crank journal off center of bore, piston pin or bushing wear.
Unless mistaken the fire crater pistons like you have were only made in thin wall sleeve sets for the H. IH really only intended those pistons to be used with gasoline heads.
Remember the piston has to be a few thousands smaller than the cylinder, or the piston would wear out in short order. The rings are designed to make up the difference in gap between the piston/cylinder.
That being said i have seen automobile engines where you could move/rock the piston in the cylinder a small amount. The rings stayed put, you could see the piston moving and the rings didn't.
Is that what you are seeing? If so i wouldn't get excited about it, that's what it was made to do. I'm not sure what the size difference should be between the cylinder and bore...I'm sure someone on here knows and will post it.
Good Luck, There is a H I drive past every time i Sub at a certain school... I even stopped one day and checked it out, but no one was home. I'd like to have it...maybe someday.
