Continental 162 engine
super bob
Can anyone tell me the standard rod and main bearing size for the crankshaft on the 162 Continental engine that was installed in the Massey Harris 101 Junior, Thanks
here is the standard crank rod and main journal size and desired bearing clearance for a F-162
Rod journal 1.9375/1.9365
Desired bearing clearance .0015
Main journal 2.250/2.249
Cockshutts used the same engine, so if you need extra parts sources and repair ideas, check that forum out aswell. My Cockshutt 540 has that too, a very dependable gashog. As long as you don't turn the crank beyond the thickest bearings available, you should have no problems...
