Continental F162
I am adding an oil filter to a Continental F162 and would like a diagram of the piping. Which port is the supply and which is the return ? One is located next to the block drain the other is located down on the lower edge of the block.
My Lincoln Pipeliner welder used that engine. I think I got an owners manual off the Lincoln website. A sweet running purring little engine.
Bill just take each plug out.. Turn the engine over with the ignition off. The oil should squirt out from the feed line.
the one just above the oil pan is the return.
there is a picture on this pdf file
http://www.pittauto.com/customer/piauel/pdf/continental_l-head_overhaul.pdf
