(quoted from post at 17:03:00 12/01/16) Welcome to the forum.
The guys have you covered on what you'll need.
I have a generator you can have if you want to pay the
shipping from Michigan. Should fit in a large flat rate box.
It worked when it was on the tractor.
Been setting on a shelf in the garage for 5 or 6 years.
I also have some other stuff you may be interested in.
6V light bulbs, a new in the package wiring harness, etc.
If you're interested email me - RoyseTractors at gmail.com
(quoted from post at 06:24:30 12/02/16) If you GOOGLE or BING JMOR's Wiring Diagrams or go to the 'other' Ford N Tractor web site, you can view and download his pictograms for free. Email is open if you need the web site link.
I just had an original '48 Ford Tractor generator rebuilt and have the correct voltage regulator for it as well. The package is complete with the VR mounting plate and the generator tensioning arm needed for the early 8N generators using the front mount distributor. If Royse can't help you, let me know.
Your early 8N electrical system is a 6-volt/positive ground set up. It uses a good AG 6-volt battery, (Interstate or DEKA are good reliable brands; correct wiring; OEM ballast resistor; 6-volt coil; -30/+30 amp induction (loop) ammeter; OEM key switch; 6-volt/3-wire/3-brush generator; and a 6-volt starter with solenoid. Lights were dealer accessories, but if you have now, and lamps are 12-volt, a 6-volt battery will illuminate them but will be dimmer. Not true if vice versa- 6-volt lamps will smoke out if 12 volts applied to them. The gen mounting plate has a pre-fabbed hole for the light switch. Wiring lights is important -DO NOT WIRE thru the ignition switch -JMOR's pictograms will show the correct way.
Many of us recommend getting some useful manuals for your N...I&T F04 is like a Bible. Parts supplier Dennis Carpenter repops many of the old N-Series parts, as well as selling some new TISCO stuff. Most Ford Tractor supply houses buy his repos and also sell them but at a higher percentage markup. I'd advise staying away from the low-budget, cheaper supply companies out there.
<center><img src="http://i15.photobucket.com/albums/a379/ploughNman/FORD8NMANUALS-REQUIRED_zps59fa6cd1.jpg"></center>
Tim *PloughNman* Daley(MI)
ick..........um? there's a reason these low compression flathead engines are converted to 12-volts 'cuz the 6-volt starter motor spins FASTER fer eazier starting. In 1939, they didn't have 12-volt batterys. I just looked it up in the MPC (master parts catalog) and it labels the battery as 13-plate lead acid battery. Doesn't even call it a 6-volt battery ...or... the modern equivalent 1-A. Only a sphincterly challenged originality authority building a trailer queen would back convert to 6-volts.(quoted from post at 09:25:57 12/01/16) Recently purchased a 1948 8N that has been converted to 12 volts. I want to restore the tractor to original. There's plenty of info on going from 6 to 12 volts but I haven't found anything about 12 to 6 volts. What do I need to check/change?
Thanks,
Rick L.
(quoted from post at 05:26:05 12/03/16) Send me an email please...mine is open...
Tim
