converting a manual bale wrapper to automatic
c.w n.y
I have a manually operated kverneland trailered round bale wrapper and i got the idea that possibly I might be able to convert it into a automatic wrapper that is operated by remote control. and was interested to see if anybody out there had successfully done such a conversion?
Is it an in-line wrapper? I remember a neighbor converted a tractor hydraulic powered wrapper into a self contained unit using a small engine hydraulic pump and reservoir. You still needed someone to operate the controls but it was knackier and freed up a tractor. If you want to convert it to fully automatic you may need to look at one that is and see what you?ll need to make it work. It?s not impossible but even if you can do all the work yourself it?ll require some valves that may not be cheap.
