Conveyor chain
flying belgian
The 10" conveyor chain in my fert. spreader keeps riding to one side. I have measured the distance between rollers and they are spot on the same. So does a conveyor ride to the long side or the short side? Which side do I spread to make it pull over?
Not sure about a chain conveyor, but a canvas conveyor will run away from the tight side.
What drives it? Is it just steel on steel, or is there a drive sprocket? If there is a sprocket, are the teeth worn off?
The front roller has teeth that fit in the webbing of the conveyor. I will try tightening the close side and see if it moves over. Thanks.
On construction rubber conveyors tighten the side the belt is closest to and it will move away that from that side. Or depending on belt tension loosen the other side to bring it closer to that side. Depending on wear on the head pulley and the tail pulley it might not run true. Running empty or with a load on it will make a difference as will running on a slope. Also how is the flashing that keeps the material on the belt, it can wear and do things to move a belt.
Mine does that, I think one side is worn more than the other, if I separate it and pull it tight it is banana shaped. But it works so I leave it like it is, and may straighten out under load but I can't see it then.
Ours will run toot running so it wears the downhill side on side hills. If it is not wearing the side of the spreader groove I would not worry about it. I don't know how old our chain is. We have had the spreader about 10 years and it was from the local fertilizer guys then.
I do know we need to do a whole rebuild on it if we are going to keep it much longer. bearings suspension chains sprockets and all. Might just be time for a different one.
