Copper head gasket QA
Diesel engines are very tight as to clearances and a thinner gasket may set up interference between the valves and piston tops. You should check valve lift at overlap to see if you can even change the thickness. If its a newer diesel with the direct injection system the valve reliefs are in the piston for just that purpose.
mEl
