Corn Picker for Farmall 460
nc460
I am not sure that this is in the right section, but I have a Farmall 460 tricycle and a 2 row mounted New Idea corn picker for it. The picker has not been on for 20 years now and I was going to put it on but noticed that I am missing the sprocket that goes on the pto shaft of the tractor that drives everything. I don't have the serial/model number at the moment. Does anyone know where I can get one of these or a place to go that might? Or can anyone give me the dimensions so I could get one made? Thanks
Have you checked out your local AGCO dealer? There still parts available for NI pickers. If you don't have one close, check out the corn picker forum. This is a great site of corn picker enthusiasts and have a wealth of knowledge and ideas. Someone there would more than likely have one or steer you in the direction of one. Just type in corn picker forum on your search engine. This forum is through activeboard.
Get the splined hub for the pto and weld the ssprocket to the hub just need to know how many teeth you need wont cost over 25
I second the Acco.dealership. I still can get most parts for my 323 picker. I will say they are not cheap but I guess they are no different than the others. You may still want to consider making one.
I talked to the agco dealer and they couldn't get the sprocket or tell me how many teeth that it had. So I guess that I will go to the corn picker forum and find out how many teeth that it has on it
