This goes back to the mid 70's and using a Sun 1120. I recall something about depending on which way the ignition point contacts are transferring material you can determine if the condensers microfarad value matches the application.
My front mount distributor 2N's ground side contact pits while the coil side (arm) has a peak to match the pit. The tractor is 12 volts, the coil is an externally mounted NAPA can that's internally resisted. Starting with freshened points gaped to .015" the engine runs fine for about 10 +/- hours of use. Then it begins acting up and eventually won't start, requiring another touch-up of the points with a diamond lap and re-gaping.
I'm wondering if by selecting a condenser of different mfd the pitting can be reduced or eliminated and the time interval between maintenance extended?
