Could use your input on Case
Hi guys, i could use some help knowing what i have to deal with or if i can. Of course these things always happen when you really need the eauipment. I have a 1989 case 455c track loader. Worked fine a couple weeks ago spreading gravel. When i got on it today no converter pressure and it wouldnt move. Nothing on the trans dipstick. Its never leaked before. I went and got fluid pressure came up and immediately went down. Got under it and trans fluid pouring out, picture attached. Any guesses on what blew and how accessible it is?
Had experience very much like yours. I thought the worst! Turned out to be a cracked fitting from vibration. Check very carefully before tearing into the machine to far. You just may also get lucky.
Start by removing the floor boards then get in on something like cross ties where wyou can pull the lower belly pan. May just be a line but cold weather is noted for getting torque convertor seals.
