Coulters. cutoffs.
Saw a Ford plow advertized . Ad said no coulters. What are the coulters for?? Also, I have read many tractor ads that mention cutoff wheels. What are those?? Not a farmer, just curious.
Cutoffs is a common term used to describe rear tractor wheels that were once steel lugs but have had the steel spokes cut off and welded to rims for rubber tires.
Dean
Yeah, sometimes coulters can be a hastle. like the guys said, stalks, root balls, misc. trash, they are suppose to cut it, so the shin of the plow will make a clean straight edge. In places where the soil will keep a an edge. Where you are, the soil and most crops won't bother you turning ground, so -especially in the hard sunbaked years, coulters will actually keep you from doing a good plowing job. cool looking if you are showing off the plow, and not using it but don't worry about 'needing' them.
