cover for operator for NAA
johnnymac
I would like to know if anyone knows where I can buy a cab or cover for the operator of an NAA jubilee. I use the tractor to plow snow in winter and it would be nice to have a shield from the weather be it rain or snow MY Tractor is an NAA. Any help would be appreciated
Johnny,
Could be tough to find - I presume you mean used? Curtis Cab is a search term I'd run with. I've seen NAAs with Curtis Cabs on them.
And are you looking for a science project or a turn key solution?
Ray
I use a heat houser on mine to plow snow in Michigan.
The one on my NAA doesn't have a cover, but the one on my 2N
does. I bought both of them used off CraigsList for $40 each.
The blue one on the 2N was intended for a thousand series.
I just did a quick Google search on "Universal Tractor Cab" and found this "Universal Fit" Compact Utility Tractor soft cab that should be close to the right size for an NAA:
[u:e6281e1244]http://www.jimsrepairjimstractors.com/compact_utility_tractor_cab.htm[/u:e6281e1244]
I also found a source for new universal fit heat housers, but that one might be a bit large for an NAA:
[u:e6281e1244]
http://www.external_link.com/Heater...p/122976.htm?gclid=CPCDzuH3-sUCFZWPHwod1Y8ApQ[/u:e6281e1244]
Then I searched on "Ford NAA Tractor Cab" and found this. They have one for the 9N/2N/8N series and another that specifically says will fit the NAA and 600 series:
[u:e6281e1244]
Dandy Tractor Cab - Modern Cabs for Antique Tractor
[/u:e6281e1244]
