crack in 12v coil
Sounds like you have an engine that is not running and your asking if the coil is the problem. Could well be but can only maybe guess since you do not give much info. Most coils are filled with an oil so as to keep them cool and insulated and if cracked they will short out and not work
Thank for comments and you are right my 1947 8n will not run no spark to the plugs. I have change out pionts and condenser but still no fire coming out of distributor.Wonder if this crack was the problem.
