Crack in cutter bar
Scott - AL
I have a vicon cm 240 that has a crack in the cutter bar below the gear box. The crack runs from the mounting bolt hole down the side and across the bottom of the pan about 2". Would welding, brazing, or using something pliable like jb weld work best to repair this? The shoe protects it from being hit by anything.
JB weld no way that would be like using duct tape on it. welding yes depending on what it is made of depends on how one would weld it and what rods to use. Brazing no since it sounds like you need something strong and brazing is not as strong as a weld
Wrote a long reply and web page went down. Here goes again.
I had a CM240. The cutterbar is the weak point on them, the next model, CM2400, has areinforceing bar there. I'm with old on the no JB weld. The one I had had been reconditioned by the dealer and it had cracks in the same area that had been welded.
The bar has to be split apart to replace oil seals for the cutterheads. If you do take it apart, I would put new seals in it while it is apart.
Filling the bar too full builds up presure and blows seals. You probably know to leave the bar upright overnight to let the oil run down before checking the oil level.
It may be possible to weld the bar with out taking it apart by draing the oil thoroughly and leaving the drain plug and the filler plug out for ventilation, then welding a little bit at a time, but you need expert advice on that.
The bolts holding the bar on have to be tight and checked regularly. Loose bolts and hitting things with the bar are the main reason for cracks IMO. The bolts holding the gearbopx together need to be checked for tightness often also.
It would be a good idea to put a new seal on the gearbox shaft while the bar is off if possible. If that seal leaks, gear oil will leak into the cutterbar, rising the oil level and blowing seals and if the gearbox run dry, you have geabox repairs.
The break away uses a shear bolt. I would but several bolts and replace the shear bolt after running a while to avoic the grief of resetting the bar and replacing the bolt in the field. Bolts are cheap, time is not.
I'm sure you are aware that is a sweet cutting machine when everything is right.
KEH
Thanks guys. JB weld sounded to easy, but I talked to a guy that swore every bar he had was repaired with it. Thats what got me asking. It can be welded pretty easy with out splitting the bar, I think.
