Crank endplay on 70D
JMJ
I am having some issues trying to set the endplay of the crank shaft on my 70D. I have added seven steel shims to the two older thicker shims that were already behind the thrust plate, and i still have a preload. It doesnt seem right to me that i should have to stack so many shims, but ive been wrong before, and was wonderin what any of you guys that have been there and done that think.
I havent dug any deeper than the out side cover yet. I was thinking about that though. right now im 60 miles away from the tractor until tomorrow some time. If anything was worn in there wouldnt i have more endplay than i would care to have?
(quoted from post at 04:55:10 11/01/09) What is the the other thrust washer's condition inside the crankcase?
70D does not have thrust washer inside crankcase. Both washers are positioned 1 on each side of F1927R thrust washer on outside of crankcase. The shims you need are F1929R (paper) and F2443R (steel) under F1925R cover. You should not need more than 2 or 3 of each.
