crank pulley compatable?
rockmike
HI guys,gals I have a TO 20 or 30 its the continental gas engine.Im trying to hookup a front hydraulic pump to the crank pulley.I removed my pulley and found I got a crack in it along the keyway,plus no holes to mount a coupler for the pump etc.So I need to find a new front crank pulley with holes other than the big one in the middle.....
I found one for a 8N will this pulley fit my ferguson TO ?
Thankyou for your help,Mike.
You are looking for this.
yes sir I am,I have found that.The ABC 1812 pump adapter will fit this pulley.I have found a 8 n crank pulley for about $80.00 and it says the ABC 1812 will fit it also.
So my question is will this 8 n pulley fit the TO 20 crank shaft while still keeping the alighnment with the W/P etc?
Thanks for the reply,Mike.
IM sure im just getting urine on my boots over this,I'll probably just buy the $100.00 pully cause we know it fits!So I can move forward on my FEL project.
Still would be great to know this compatibility issue...im currious.
Thanks!
Since the 8n motor was made by Ford(AFIK) and the
to 20 was made by Continental, I seriously doubt
if the pulleys are compatible, but you never know.
KEH
Looking at more pics and such im fairly confident that the 8n pulley is NOT compatible.The fergy pully has a step in it and the ford one doesn't, pretty sure the W/P pully would not line up.
Sure appreciate y'all brain stormin this with me.Thanks!
