Cranking problems on rebuilt H
SRH
Hello I rebuilt my H> it has new sleeves,new dome pistons,rings> 6 volt positive ground,new wiring,new coil,new battery,new 2 gauge cables,new starter switch, all the connections are clean and tight. All that to say it will only turn over once on a new fully charged battery>if i am lucky it starts and runs great>if i miss that 1st try i have to push start it>and if i shut it down it won't trun over again> only have about two hours of run time on new rebuild.Any ideas? does it need to be broke in> too much compression? would apprecite any thoughts P.S the starter switch, Cables and coil are always warm after 1st try Thanks
Run it more so your new pieces start fitting together better. Then it should loosen up some. Sounds like it is a little too tight. Heavier cables might help but if it is too tight those cables will still get hot some because they are working harder than normal.
The cables for 6V should always be 00. You may want to upgrade it to 12V with the domed pistons. It will start much better and you can run the timing a little more advanced for better power.
The 2ga cables arent big enough get at least 1ga and have the starter checked out and rebuilt mite be cheaper to get a rebuilt one from Harvey Bros or a new on for around 150 then you will be good to go. The tractor started when it was new and it will again but things have to be in new condition.
As the others have pointed out you need 2/0 cables with crimped and soldered (not clamped!) terminals.
If the engine still cranks slow with the heavier cables the component in the starter circuit that gets noticably warm while cranking is the problem.
Most likely culprits are the starter switch and the point where the ground cable bolts to the frame. However if the cranking circuit stays cool then it's the starter that needs attention.
Had a similar thing on a 300. Changed power cable, added a new dedicated ground from bat to the starter, tried a new starter. None of that ever fixed the problem. I was able to measure the amperage during starting, was getting over 500amps, it seems that is locked rotor amperage for the starter.
Finally broke down and converted to 12V. $80 for the alternator, I used the electronic ignition so $120 for that, about $40 for misc other stuff(lights and stuff). Now she fires right up, almost before you turn the switch.
