Please describe what are you call a crib block? To me timber blocks like 4 x 4 or 6 x 6 about 2 feet long are cribbing blocks. Stacked two wide with the next layers alternating 90 degrees to the ones below would be fine under a frame. Singles just stacked one on the other, not recommended.Mostly I see crib blocks being used under tires. Is it save to use them under frame locations and or axle locations?
Thanks for the help.
Bill
timber cribbing should be fineI was referring to timber cribs of either 2x4 4x4 4x6 6x6 screwed together or fastened some how together. NO concrete or cinder blocks involved.
Those are not cribs because they are not designed for stacking as in the picture that janicholson posted. The blocks that you describe are most likely to be used under tires, but only when in width of at least two times wider than the tires. and in a height of no more than half the width.I was referring to timber cribs of either 2x4 4x4 4x6 6x6 screwed together or fastened some how together. NO concrete or cinder blocks involved.
Also as I posted, alternating layers at 90 degrees to each other.The cribbing I found an image for are just stacked like shown, no fasteners. Jim
I am a strong believer in properly used solid wood cribbing. However I did have a bulldozer on cribbing with the tracks off and was under it with a 3/4 drive breaker bar trying to get a stubborn bolt loose and twisted/slid the whole machine on the blocking, luckily it stayed on the blocking. Always be careful.Mostly I see crib blocks being used under tires. Is it save to use them under frame locations and or axle locations?
Bill
Later in that document they cover the vertical shoring and show examples where there are multiple vertical elements, thus why you have the top beam to distribute the load across the vertical piles. Also note that it is a doc for emergency services and not necessarily what you would do on a nice controlled building site. Either way these docs give a good overview of using they typical cribbing stacks and and idea of the significant loads they can carry.Boy I don’t know on the last one of those from Montgomery county. Be very careful if standing the cribbing vertical like that they show it spread out nice and crushed into the perpendicular cribbing but I’ve seen people especially split wood that way if they don’t use the perpendicular on the top and bottom. Also if this is needed why bother with the load bearing number that is higher since you must use the perpendicular one anyway? Good pictures though!
