Cub and Woods 42
I have a '49 Cub and just bought a Woods 42 mower. I have hydraulics on the Cub but I do not have the piece that attaches from the control arm to go from the tractor to the mower. I have no idea what the part is called and I would rather use what I need than to just use a chain. Please advise. Thanks.
I would call it a lift bar, but you're not likely to find it in the wild. Woods might have it as a replacement part but they probably want as much as you paid for the mower for what is essentially just a couple of pieces of flat bar with holes drilled in them.
Exact dimensions aren't important. Close enough is close enough. I personally would just go on google images, find some good high-resolution images of a side view of a Cub with that mower on it, print it out, and get rough dimensions from that. The front rim is 12" in diameter, so you can use that to make a scale to measure the lengths of the pieces.
