Cub Cadet 125 Hydrostatic Drive Problems
Josh M.
Location
Northeast Ohio
Recently my Cub Cadet 125 has been moving on its own after I put it in the neutral position and get off, It will just start to move backwards slowly and I cant figure out why. Not sure if the pump needs rebuilt or not but if so where could I find a rebuild kit for it?
Hi, jack up the back end. Remove back wheel. Get some one to sit on seat and start motor. Put in neutral with shifter. You will see 2 bolts to loosen and move to where the axle doesn't turn. Put lever to neutral and retighten bolts. 10 min fix. Ed Will Oliver BC
