flembo
Kohler Magnum 18 Hp M18S Last summer it started showing negative amps when first starting but then would show a charge after a few minutes of running but this year it isn't charging at all. This is on a Cub Cadet 1811 with 2400 hrs. any suggestions as to what to look for. Also on a second note it seems to be loosing reverse some times it will go 3 or 4 feet then stop and I have to go back and forth between forward and reverse several times to get it to go but it will have no power and won't back up a slight hill. Forward seems ok and the 3 pt hitch has plenty of lift. I changed the Hydraulic filter and and refilled what was lost with Cub Cadet brand fluid and the fluid looks clean. It has always been a great running tractor and has given me no trouble until now. Any help would be appreciated Thanks.
