Cub Cadet V/R
I have a Cub 127. When I got it, It wasn't wired completely and not running. I hooked it up enough to get it going. The Voltage Regulator was wired except for a ground, when I connected it, the V/R smoked and it shut off. It had 4 contacts. It runs good now just no charging system. I have another V/R with 3 contacts and it looks as if the case is to be grounded. Can I attach it to the frame w/ a ground wire under it? And do I need to polarize the system? Should I mount it on rubber just for vibration protection? Thanks for any help Kevin
