Were do I begin. The old tractor has been sitting for years now due to rear mainseal leaking. I have put a new battery on it but it won"t do anything. Could it be a bad ignition switch? I was going to crank it to move it to change the seal. Now I have many questions about this tractor are there any safety switches on this tractor? I could not find the starter. I see what appears to be a generator. Could that be the starter as well as generator? It sits on top of the motor and has a belt running off the fan. Do I have to pull the motor to change the rear seal? It looks like I could pull the drive shaft and possibly remove the flywheel to change the rear seal. I turned on the gas and it started running out of carb. I guess I will have to rebuild it too. Thanks for any help.
