cub lowboy 154
my cub lowboy 154 will not move unless i hold the clutch just right and will not move at all in 3rd gear is this a clutch problem or something else
Clutch, they are a little odd but easy to get to just remove the tunnel between the dash and the rear cover,4 bolts I think. I have seen the fingers wear off and when you put it together, you have to adjust it so the clutch releases and also so the clutch brake works too.
