cub-part # location for hydrallic pump
Tom Durrer
Need to order O rings for the hydrallic pump on my 1951 farmall cub. Can not find the part # for the
pump which my parts supplier needs to find the correct rebuild kit.Can someone help me located where to find this part #.
Thanks Tom
There is only one rebuild kit for a Farmall cub hydraulic pump. IH part 355208R91. The exception being that some of them use an oil seal that has to be ordered separately. You can get the kit from TMTractor dot com for 27.88 plus shipping. Comes with complete instructions.
The parts place may have been thinking about the Touch control unit itself rather than the pump. There are 2 different kits for that, and the numbers are cast into the housing.
Thanks guys. John you were right, one kit
exception base on diameter of pump shaft may need
separate size O ring for shaft cub if model has 1/2 shaft diameter. Ordered kit from
Farmall forever website. Very knowledge folks.
YT did not have it in stock.
Tom
